I just bought a gently used 2009 Scag Wildcat STWC-61V with a 61 inch Velocity Deck (500 hours). I'm having issues getting the deck height raised to match the indicator on the mower. Basically when I set the mower in the 5 inch slot, the blade to floor measures 3.5 inches. I have adjusted the mower just as the manual instructs (height adjustment on the foot peddle to raise the deck) but cannot for the life of me get it to raise any higher. The deck is perfectly level on all four corners. Has anyone else had this issue? Any suggestions on how I can fix this issue? I would really appreciate any help.
I have debated on raising the suspension chains on the deck from the factory 5 link to link 4 or 3 as this would work to get the deck higher. However, everything I have read discourages this as the 5 link chain is where it is set at the factory. I'm just wondering if this is the right thing to do or if it would negatively affect the mowing deck.
Again, any help you can provide would be greatly appreciated.
