Engine 2008/2009 XC3366 Generac Replacement
J&SRailway
Hello, I recently had the original motor on my 2008/2009 Dixie snap a rod, Does anyone know what motor is a direct fit for this motor considering nobody is able to rebuild the motor
contact Small Engine Warehouse or Small Engine Supliers.
Replacing engines is their bread & butter.
usually they will have a surplus / superceeded engine in stock really cheap.
try also Bradley Mowers in Bradley IL
they shipped a Briggs and Stratton engine to me, that i replaced in my 05 Dixie Chopper
aside from a bit of issue with the wiring and having to cut / tap the crank shaft, it was an easy swap
