dirtyharry
- Nov 17, 2024
- 6
My x300 has no power to the ignition switch. Battery is fully charged and mower will start if i jump the solenoid. I checked all the fuses and safety switches. The ignition switch checks out too. No power at any of the terminals. The fuse block is a little confusing. It has 3 fuses, 15, 20 and 7.5. All are good but when I look at the back of the fuse block it seems like only the 7.5 is wired right. The others only have wire on 1 leg. See pic. If there a fusible link on this mower?
