Repairs 2007 Cub Cadet i1050
Canada_CT230
I'll try to keep this short and hopefully someone can help:
- Tractor does not turn to the right.
- Tractor slower in stright FWD travel.
- LH hydro-gear turning or not turning when wheels jacked up off ground.
- LH hydro replaced, no change.
- Drive belt replaced, no change.
- CC manual followed to wheel alignment and tranny setup, no change.
- All adjustments to steering and tranny appear to be setup right.
WTF? This is raising my blood pressure. There appears to be no adjustment on the tranny linkage but it appears that the hydro gear needs more throw on the linkage to extract full power.
HELP!
KennyV
Is this the same mower that was in warranty a couple mts ago that you mentioned had the hydro replaced??
As I recall you were having a pto issue that may have been related to that dealer service work... could this also be related? ... :smile:KennyV
