compusatman
- Jul 2, 2011
- 2
- 3
Ok guys, be easy. I had a stroke in "11 and reading takes a while now. So please bear with me. I have searched to the beginning of this topic and I don't find any relevant posts. So here you go. I have a 2006 Turf Tiger Kawasaki and never an issue. I got out of the business but still have my equipment. So I began to mow last week and it would run for a bit and then die...repeat... The flash codes from the "computer" gives me 112. I am told the code is actually 12 because the initial flash is a confirmation flash that the system is working. This from my dealer. As well, that the 12 code is not pointing to a particuler system...or part. So can someone help...or at least point me in a direction? I haven't changed the oil in a while and was thinking there might be a time reset on this service. Anyway, it runs fine for a short period then dies. After a bit...it will start back up...then same cycle. I'm running the original battery. But it doesn't show a dead cell. But I am old enough to know that simple things are the most common issues. As I say, the battery shows good voltage and takes a charge fine. No evidence of a dead cell. Could a dirty oil filter cause this shutdown? Anyone?
