onehandman
- Oct 30, 2022
- 2
Hi everyone,
I was given a 2005 Exmark Z laser 60 inch cut with a kohler 27HP. It is not EFI. Lately when the mower gets warm it will start to bog,backfire(out exhaust), and die out when mowing/under load. If you choke it it seems you can keep it from dying out, but it still doesn't run correct. The machine does have 2100 hours, but it has something going on(not base engine), both cylinders have over 100PSI and I have check valve lash. All of the safeties were previously removed so I do not expect it to be a safety switch as the cause. I believe something is getting warm the from engine and starting to fail, and was hoping this may be something common on this year mower.
Thanks in Advance.
Paul
Thanks in Advance.
Paul
