rapidride2
- May 11, 2013
- 14
I've learned that the green and black wire running to the interlock module is indeed for the starting circuit. I also must reiterate that when my mower dies that i have spark and coil voltage when immediately testing during cranking. This is whether it starts or doesn't so i'm narrowing it down to being more of a fuel issue. I did replace the fuel pump, filter and removed the fuel cut-off solenoid in the base of the carb bowl (although this worked 30x in a row when bench testing with 12 volts) . I'll continue to keep my eyes peeled for any issues. Mt father will cut this week. If i can get through 2-3 cuts without any dieing issues I will assume it to be repaired. If not I will continue to scratch my head.
