Newbie to the forum but not to a wrench but I still need some help.
Short version of the story I was gifted for a project a 2003 Z Force 48” model 53AA5A7M710 With the Briggs motor. When I got it, it had been sitting in a Kansas field for a while.
When I first got the motor running any time I touched (release) the break the motor would shut down so I got to work. Somehow I corrected the issue and the mower would drive, run, mow and basically do what it was supposed to.
Now after getting into even more I’ve replaced the starter, tires, PTO switch, oil, filter, fuel lines, fuel filter, bellcrank, clean/checked every switch and terminals and a battery. I’ve gone through every safety switch all wiring and connection and everything looked great.
Last night I took the mower out for it’s welcome back to life mow and it did good. So I pulled it into the garage. Now every time I turn the key it starts but dies when I release the break.
Now I would prefer to get the problem actually fixed instead of just checking all the connects again.
PLEASE HELP if you have a idea...
Thanks in advance RJ
