oil temp gauge stopped working after winter storrage. Appreciate any help. Thanks, gepp
G gepp Member Joined Apr 16, 2012 Threads 6 Messages 13 Mar 21, 2014 / 2002 toro 522xi #1 oil temp gauge stopped working after winter storrage. Appreciate any help. Thanks, gepp
M mechanic mark Lawn Pro Joined Jul 15, 2013 Threads 175 Messages 7,427 Mar 22, 2014 / 2002 toro 522xi #2 Check all connections for corrosion, rust, and being loose. You can use a multi-meter tool to check gauge out.
G gepp Member Joined Apr 16, 2012 Threads 6 Messages 13 Mar 22, 2014 / 2002 toro 522xi #3 mechanic mark said: Check all connections for corrosion, rust, and being loose. You can use a multi-meter tool to check gauge out. Click to expand... and loose it was. Thanks for the help
