The seat switch has absolutely nothing to do with any of the starting circuits so leave it alone.
The cranking circuit goes
Solenoid hot terminal > fuse > B terminal on key switch > S terminal on key switch > PTO switch > parking brake switch > trigger terminal on Solenoid.
This is a daisy chain so any single break = no crank
You can back check the sockets for voltage but that requires third hand on the key switch, or jump each switch one at a time till the culprit reveals itself .
Warning
The PTO & BRAKE switches may also have magneto kill wires and connecting them to 12V will fry the control chip in the magneto.
Get a wiring diagram to make sure you don't blow the magneto or pull the blower housing off & disconnect the magneto kill wire.
Seat switch is bypassed by the brake switch so as long as the brake is on & PTO is off you can start the mower with an empty seat
Otherwise it is a tad problematic for techs to service the engine
I did a push button start on mine when the ignition switch went out. Alot cheaper and easier to do. Total was 10 buks for the kill switch and the button switch
Just jump started it and for testing, I engaged the mower PTO without anyone on the seat. Isn't the safety switch supposed to shut down the engine when the seat is empty?
Yes it is so you obviously have some wiring problems that should be sorted out.
The seat switch is there for both your safety & the safety of others in the locality of you mowing
So I shut it down, engaged the PTO, not sitting on seat and jump started it with the PTO engaged --- it started.
If you read & understood my original reply then it would be apparent that jumping directly to the starter motor bypasses the entire cranking circuit so why would it not start ?
Now my thinking is that maybe jumping the starter bypasses the PTO safety switch? But shouldn't the negative side of the switch not allow ignition.
Well yes if you are not using the cranking circuit a safety switch in the cranking circuit is hardly going to have any effect is it ?
There is no battery ignition, the Magneto is self energising so nothing there to stop the engine firing up & blades spinning lopping off a lump of your hand or foot while you are there jumping the starter or you slipping & putting your hand into the belts on the deck, so the belt can not so neatly remove large lumps of flesh.
The safety switch for the PTO has four spades. For testing purposes, I'm not sure which female sides of that connector to jumper and bypass the safety switch.
There is a golden rule about staying alive & well
If you have no idea about what you are doing then DON'T DO IT
I was originally trying to help you diagnose & fix your mower
However you are obviously determined to bastardize the wiring with less than no idea what you are doing & the potential consequences of doing it.
Thus you are now on your own
That's a little harsh. You would hate seeing my mower as I bypassed all safety switches with the push button start.
Whoa!
At the moment I have a broken finger, on antibiotics for Lyme, I'm 66 years old, I'm sitting with my neighbor some days, the one dying from cancer and all I want to do it get my 2.5 acres mowed. I really don't have the time or the physical capacity to crawl around on the ground. Now if you can tell me exactly which switch is crapped out, I would appreciated it.
Almost everyone around my area has disabled one or another of those safety switches at one time or another. Maybe over the winter I can get it set perfect again.
Yes I do live in an area that we joke about all the government BS that is here for our safety. We all have our feet, our fingers and some of the guys are in their 90's still crawling up onto their tractors to plow the fields.
Oh and yes, since my home isn't three prong receptacles, I also cut off that third ground off my wires.
Look I see both sides of the story. On one hand yeah it should be fixed with it all working 100 percent. But sometimes you have to bypass things to make them work to get the job done. Take my mower. Yeah I bypassed every switch it has. You know why? Because I don't have 25 bucks for a ignition switch plus other things. Do I need the safety switches no not really because I have common sense. Just like a car I don't start it in gear. And let's be honest here. Most safety things are there not to protect people but the companies from being sued. So let's all. So let's relax everyone grab your internet beer and not take this that serious. We're here to help each other out not bitch at each other.
