H huck18 Forum Newbie Jul 24, 2018 #1 my pto keeps cutting in and out, I replaced the pto switch today but it didnt fix the problem, wiring looks good, any suggestions please
B bertsmobile1 Lawn Royalty Jul 24, 2018 #2 Check the battery voltage with the clutch on and off. If it is lower with the clutch on you have a charging problem.
H huck18 Forum Newbie Jul 24, 2018 #3 bertsmobile1 said: Check the battery voltage with the clutch on and off. If it is lower with the clutch on you have a charging problem. Click to expand... with the machine running or with just the key turned on, thanks
B bertsmobile1 Lawn Royalty Jul 24, 2018 #4 huck18 said: with the machine running or with just the key turned on, thanks Click to expand... Running. Some clutches will cut out at low voltage to avoid drawing too many amps, some don't. Most will not work under 10V, some will work as low as 6 V
