Stlouisramsfan
- Apr 5, 2015
- 1
- 2
Briggs model # 28B707
type 1153-E1
Been sitting for a while, thoroughly cleaned carb, including removing the emulsion tube/main jet.
Runs great for 1min. Then the engine Boggs down, dark visible black smoke comes out of the exhaust. For maybe 20 seconds, then runs fine. I have not tried to load the mower with the blade yet....
The governor seems to jump around while it is bogging. Not sure if this could be an idle circuit in the carb, I haven't found a good YouTube video on that part
Any advice insight is much appreciated!
Thank you
Chris
type 1153-E1
Thank you
Chris
