2000 Grasshopper 721
66vette
When just started and I slowly accelerate the Grasshopper wants to jerk continuously when moving forward until I pick up speed. Makes it difficult to ease around flower beds etc. After a while it will stop doing it. It is not a choke issue or engine issue. Is it hydrostatic belts or some other mechanical component on the hydrostats?
When was the last time the hydros oil and filter was changed? When was the drive belt last changed?
Well, let's start with that. You are past due for your first and maybe your second oil change. Belts get changed when needed and most people go way beyond the belts life.
On page 13 of Eaton's PDF on the 771 trans.
