20 Hp engine
jackz
I have a Kohler 20 hp command pro series 64596 and would like the same to replace what I have . The used engine is about 8 yrs old Is the same engine still current ?
577jersey
You could put a 7000 series on that,,they are good engines and affordable.
You should be able to find one if you look at the remaindered engine , clearence engine & superceeded engine specialists like Small Engine Warehouse, Small Engine Suppliers.
Some of the surplus centers had a few a while back.
