Dhunter0047
- Apr 4, 2021
- 1
- 4
Purchased a John deere gx345 which got a engine swap with I believe a 20 hp briggs intek engine and I have 2 major issues I need figured out.
1. Can not get it to charge a battery. Starting and driving around it does fine but as soon as pto is engaged it starts losing power. It has the red wire with diode and black wire from stator. It will only maintain around 12.8 to 13 running full throttle no load and drops to 12.4 when pto engaged.
2. It will not start on its own. I always have to pour gas in carburetor to get it to start then it'll run fine, and you can usually shut it off and restart after that for a bit before you have to gas it again.
Any help greatly appreciated!
