2-Stroke Jet
Gsnod
Hello;
The small jet on my 2-stroke snowblower is lost, and I need a replacement. I can't find a part number, but do have a graphic of the part. This is off a Tecumseh Model TH098SA and I believe the carb is # 640092A 5261. The jet is #20 in the attached graphic.
Does anyone have a part number so I can get a replacement?
Scrubcadet10
Moderator
Staff member
I would check your local repair shop, as the should have a few of those old carbs laying around. That idle jet was the same for many different carbs. Might cost you a half dozen donuts.
Gsnod
Thanks Rivets! That's probably gotta be my next step.
