- Sep 7, 2024
- 3,515
Does anyone remember the (old) days before canned "pre-mixed" boutique fuels for 2-stroke equipment?
I worked in a small engine shop back in the late 70's and the rule was to keep life simple and get the job done. Mixing 2-stroke fuel was not a "rocket science project". There were no canned pre-mixed fuels back then that I was ever aware of. We kept one jug mixed for weed eater and chainsaws and the another for Lawn Boy 2-stroke mowers.
I also recall many cold mornings cutting cords of wood for winter and summers cutting roadside weed stalks for local ranch owners. I mixed my fuel as I used it, not in bulk to keep for "next time".
Typically, in the shop all we would do is mix a couple of oil bottle cap fulls of 10W-30 into a gallon of gasoline. When we ran the engine, we would simply watch for a little light (very faint) blue smoke.
When it came to my own SS30 Green Machine straight shaft cutter with a saw blade, I would fill the fuel tank and add about a half cap full of oil and then shake the machine for a minute to mix the fuel in the tank.
Times were simpler back then as long as I paid attention to how much oil I mixed in the gasoline. No smoke, not enough oil.... too much smoke meant too much oil in the mix. I made adjustments as I went along. It only took a few drops of more or less of oil in the mix to get the desired results.
Sounds too simple but it was meant to be. Now advertisers have people buying cans of pre-mixed canned fuels for some crazy prices and that stuff does not keep forever on a shelf in a sealed steel can.
On a side note: I never straight gassed and burnt up a motor cylinder and piston. I also never had to pull mufflers and burn them out with a torch due to excess oil coking/carbon buildup. (Ive had to do that on quite a number of canned pre-mix fuel machines.)
In recent years I have had many customer machines come in with "canned fuel disease" that were hard to start or not run as they got warmed up good.
