Find the engine's model numbers and put them up.
Looking at the model number is key to giving any sound advice.
I have replaced air filter, plugs, checked gas and engine will still only run smoothly with choke 1/2 on
B&S 19HP
Any suggestions?
View attachment 43020Here is what his carb looks like, and that plug toward the camera is the one he needs to remove to access, remove,
and clean the main jet. Most times that is all that you need to do to get going again.
After removing the jet, crank the engine a little and let the water and crud pulse out.
Then re-assemble.
I described this a little in post #7 of this thread.
Yes,
knowing what engine he has is "key" to giving him good advice.
Could you please chill out. Everyone has their own style of helping here. Taking on someone else's style isn't helpful.If so, than please explain to me what other advice would you give him for this problem on any other engine? I would give him the exact same answer no matter what 4 stroke gas engine he listed. Clean the jets, if the fuel bowl is full.
Particular carbs and particular engines have known problems or know covers or plugs that either need to be removed to be cleaned properly or are best left alone because they are difficult to remove without damage or difficult to reseal and rarely need cleaning behind.
Some of the carbs used on the twins have inbuilt fuel pumps and the fuel pump is more prone to cause the problem described than the carb itself.
Some have removable jets that just push in or screw in while others have jets are fixed and attempts to remove the jet can damage them
Some have screw in jets that need to be removed with an exact close fitting screwdriver or you damage them.
Some venturi tubes have cross drillings that ned to be cleaned, some do not have cross drilings so do not need to be removed and some venturi tubes are cast in or sweated in and can not be removed without damage to them or to the carb.
Then you get to the seats.
Some are removable some are not.
So to give good specific advice and approprite warnings the engine number is needed.
Then you get differences in the understnding of what "cleaning" means.
Some will squirt some throttle & body cleaner down the venturi and consider the carb cleaned
Others will no consider anything clean unless it was fully dissasembled and boiled in an ultrasonic cleaner for hours.
When the thread is read at a latter date by some one who is not sure of what they are doing , it helps them to decide if this is the correct thing for their engine or not.
Thousands of people simply search the site for possible solutions to their problems and never ever post.
Most question could be answered with the single annogram; RTFM but that is not much use to the poster with the problem.
Also model numbers help the techs who oft skim through the forum and occasionally give the correct answer to the wrong question.
If one goes taking apart this carb without know where to go/do, he will take apart the fuel pump and lose the springs
and will not put it back together correctly, have to remove the whole thing, spend a bunch of cash he didn't have to, when all he needed was a socket and an allen wrench.
So I always ask for pics or a model number, so the advice I give will be as accurate as possible, and save the poster as much money as possible.
But that is just me......
I guess I just assume people can put stuff back together. I have been in aviation maintenance all of my adult life. It just come natural to me to put something back together. I can usually put most things together even if I am not the one that took it apart.
The info in post # 12 should have been helpful to MOST anyone with a mechanical background ! ..![]()
I am kind of on the opposite of this.
I know most folks cannot take stuff apart, and put it back together correctly. So I like knowing what model they have, either by model number, or at least a pic.
I like to tell them what I know to save them time, headaches, and money, if I can.
Otherwise I just do not post much more on it.
This model is an easy fix, if you can catch them before they tear into it, and knowing what they have is needed to help them fix the problem.
That is all.
No hard feelings.
On this model, if they take apart the fuel pump, the springs go everywhere and are lost, so a new kit there is then needed. And putting it is back together correctly is difficult without removing the whole thing, and it would have been fine if they just left it alone. Just trying to help the original poster in the best, quickest, cheapest, way possible.
I didn't click those links. I am more of a just do it type of guy. I hardly use books, and when I do it is just for specific specs. Like gaps, or voltages, that kind of thing.
Hard to tell by typing, are you trying to infer that I don't have a mechanical background?
NOPE .. NOT AT ALL ! I too was an an aviation mech U.S.A.F. Jet Eng Mech ( AFSC 43270 ) ( 66-70) B52s & EC-RC 135s , after military on & off for about another 15 years C-130 Hercules (covert transports), Lear-Jet and several others, I was taught to use a manual at all times, ( it was enforced ) to this day, if there's a manual for it, I use it, (including the wifeys carpet shampooer & Micro-wave) it's a proven fact that being complacent, will SOMETIMES lead to undesirable results. ....Just my thoughts ..
Cool thanks. I started in the Army working on the AH-64 apache got out in 1996 and then worked fixed wing at a small place for about a year. Then hired on with Bristow (actually back then it was Air Log) in 1997. Been there ever since. Worked on so many different types of planes and helicopters that I can't keep track. Some of the crazy torque sequences now you have to use the manual. It literally takes about 6 hours to torque 8 bolts on the main and tail rotor of the AW-139. It sucks.
I loved workin on the "birds", only problem with them, is they cram 10 Lbs of schitt into a 5Lb. bag, .. :laughing:..:laughing: everything is SOoooo tight for aerodynamics, as you most likely know, sometimes you had to remove other components to gain access to the item you need to repair/replace ARrrgghhhh !!.. :thumbsup:
Yes, you should see the ones with floats on them. All of ours are equipped with emergency floatation. Packing those things in is a real PITA.
Here is one of the ones I take care of right now. This is a S-92, the other is a AW-139, and a S-76 C++.
I feel your frustration, and I don't miss that part of the job, GLAD to B retired, hope U don't have long to go for yours .. :thumbsup:
17.5 years. Wrapping it up at 62.5.
DAM Helo, U B a YUNG-UN !! .. me B pushin on 73 !! .. :laughing:..:laughing:.. :thumbsup:
Sometimes as someone pointed out way back in the thread that an air leak in the manifold, carb to manifold or manifold to head mounting MAY cause the same issues. Glad everyone now sees how each of us deal with the same problem, seems a lot of folks say the same thing but use different words.
Question for the helo mechanics in the crowd: what is the torque specs on the "Jesus Nut" for most birds? :smile:
Tom
