dwelder
- Jun 19, 2011
- 12
I have a twin cylinder 19hp briggs. I recently replaced the sump housing because it was cracked. I have 2 questions. When I took it apart I couldn't figure out what this machinisem was, it looked like it has butterfly flaps and has a gear on the end that connects to the main shaft gear. Back to the main problem. When I put it back together it ran wide open. Does the governor need adjusted or does the butterfly thing have to do with the governor.
