any help would be greatly apreciated. i have cleaned the carb ,rebuilt fuel pump and put in new plugs. however she still wants to surge .i have cleaned the govenor good as well . just a little confused now thanks andy
Have you adjusted the carb? If it has a screw on the bottom of the bowl, then give it a twist while the engine is running. If it's not there, it will be somewhere on the carb body.
If your sure that the carb is cleaned, you should find several different settings on the governor... try another hole with the tension spring...It may have been placed in the wrong spot... :smile:KennyV
If your only getting half the ignition I would have thought you would have more indications than just surging...
I'm sure having both cylinders firing will smooth that engine right out. :thumbsup:
Post back with what you find... :smile:KennyV
#9
Briana
WELCOME to LMF
I moved your thread to the Small Engine & Mower Repair Forum. :smile:
Good to hear things are looking good for the end of the season, leaf mulching time... You'll be all set for next spring...
Thanks for posting back that things are looking Up.... :smile:KennyV
