- Sep 7, 2024
- 3,492
Hello G.,Thank you Doc. Makes perfect sense on the shim and I can see it did have a little wear on it. McMaster Carr may have one similar.
I did see that repair on YT by Teryl and have seen a lot of his videos over the years. It seems as if others have also copied his idea as they are using the same procedure and 10-24 set screw, I may go to a 10/32 set screw. It is not a problem for me to do as I am setup with small machine shop for the vette diff's I build, so I should have everything here. I haven't put a straight edge on the head yet but I will, just to make sure it's not warped. I can set it up in the Bridgeport if needed but I think it may be ok. The head gasket was still good and one I replaced several years ago.
A correct size roll pin punch or a shoulder punch with a shop press works nicely for getting the guide out of the head pushing towards the top and then when you place the guide back in position (A hammer will work also but be careful). There will be an age line from the old oil resin on the top portion of the valve guide that will indicate where it should be in relation to the head. Both guides set about even otherwise.
The careful part is the drill stop depth, threading the hole and setscrew placement.
A flat section of tempered glass and 600 grit paper is what I have been using to relevel aluminum head for years. A Ron Popell rotisserie door to be exact, but I have used the glass kitchen table top a couple of times (Don't tell the wife)
Don't reuse a modern graphite coated head gasket once it has been run for any amount of time. These are not like the old "flat head" engine foil side gaskets from years ago.
I've never had to have a head milled and hope I never have to.
