Hi
Can anyone recall how to make repairs to the controls. I just need to figure out how to replace the key switch. This one has a plastic plate over the top of the tower and the steering wheel and some kinda level is at the center. It has a tuff piece of accordion plastic that surrounds the steering wheel base and I pushed it down and saw a bolt with a nut that looks like it is holding the wheel on the column. I am afraid I will destroy that plastic collar by pushing down on it to get to the bolt. There were no screws on the sides only about 4-5 screws on top of the black plastic plate and after removing them it would not lift high enough to get to the key switch. I lifted the hood and did not see and way to remove the gas tank to get to it from under it. I started to try harder and thought better of it and decided to seek information.
Any insight would be appreciated. Thanks
