Export thread
1993 MTD blades for 46 inch deck
#1
J
JayBo
Good morning, hoping somebody here might be able to lend me some insight. I'm looking to replace blades on my 93 18/46. 942-0543 and 0542 is what's called out on PartsTree (for 96 and older mowers). However, I've found some pretty good deals on Amazon for a set of 0611 and 0612 (97 and newer). I know the blades look a little different. The middle blade is 3/32 longer on the Amazon set, and the outer's are the same dimension. Both 6 point star hub.
Can I use the 97 and newer blades on my old deck?
Thanks in advance!
Jason
#2
B
Check theblade lenghts very carefully.
The longer middle is highly likely to strike the other two when it is running.
