Thanks a Ton for the compliment and encouragement. That means a lot to me.
I put a lot of hours into this restore and I'm just about done... This was my first honing believe it or not. So I have one under my belt now. Won't be the last. I do a lot of reading, watching videos and looking at repair manuals, becoming familiar with the parts and seeing just how available potential replacement parts are before any disassembly. I have rebuilt an old 1970 Onan Generator engine. So this didn't seem to hard. Just a bit different in design. There was no way that I wasn't going to MIC everything that I could to find that knock. This is the first of a few noises within my small fleet of machines that I'm going to be taking care of.
I Got the engine back together late last night with a small bottle of assembly lube, some rags, parts cleaner and some 9mil gloves.
I set a goal of honing and getting it rebuilt for the day and didn't want to go to bed until I did everything that I could. Today I've sprayed my last two parts. The PTO pulley's underneath. I had to weld a crack in the bottom of the exhaust manifild that was spitting carbon on the old paint finish so that was a must to fix. Got that fix and mounted the engine on the engine deck. Finished with the initial throttle, choke and carb settings. I need to fix a couple of raw rubs in the wiring harness, get a few 2.5" mounting bolts for the new (used) oil filter bracket an oil filter, oil, lube everything up an the last touch I'm going to pickup today... DECALS...
I couldn't find the pull starter decal anywhere so I carefully removed the three decals and ID tag from the cowl and designed my own decals for the top of the cowl and pull starter on my computer software and I go to pick those up in a few! Hoping to get it started before the night is over.
More Pics...
More to come later...
P.S. I also have tear down and repair pics if anyone would like to see how bad the deck really was... Put it this way, The only reason I spent half of the build time with repairing it was because I couldn't find an other one. But she's solid as a rock now. New bearings and bushings and all. I took the spindle completely apart as well a the drive wheels and their pulley's and the levers that move them. It's all tight again like new. It's going to be hard to sell this thing, if I can bring myself to do it.
