1986 Deere 214 fuel filter
CorkGuy12
1986 214. Need to replace Filter below gas tank. Anyone know the John Deere part number or a non John Deere part number which will work as a replacement?
MParr
That’s fuel drain/shut off valve. There’s a screen built onto that valve that is inside of the fuel tank. If there’s a inline fuel filter on the tractor, it will be downstream from that valve.
Is the valve functioning? To test, close the valve and remove the fuel line. Have a container ready to catch the fuel and open the valve. If you have a good flow, nothing is wrong and you can put your fuel line back on.
Tell us the problem that you are having.
Give us the complete model and serial numbers of your machine.
Type this into your search engine and you should find more info than you need.
”small engine in tank fuel filters with shut off valve”
