Export thread
1961 mtd 1400
#1
W
wonder33
What do they use for fluid in the transmission!!
George warner
#2
B
going to depend upon the actual box fitted.
Anything from engine oil to light grease to Bentonite.
#3
W
wonder33
How can I tell????
Thanks George
#4
B
When new there was a tag on it which might still be there.
If it is an MTD box it will have a code number cast into the casing.
Then there is the way it works.
If it has actual gears like a car with a reverse position then you need grease.
If it has a foot pedal for speed control and another lever for F-N-R
Then it may need liquid grease if it has a diff only
or 20W 50 synthetic if it is a full hydro.
Some photos would be of great help. particularly of the speed controller.
