sihamilton
- Feb 19, 2014
- 6
Ok, but if I insert the spring into the same holes on each end of the linkage, wouldn't that negate the effect of the spring?
That spring is there to keep constant tension between the air vane and throttle. It is used to help make sure that when the vane moves, the throttle reacts as quick as possible, no lagging behind.
that spring is to eliminate binding of the linkage,if im not too far off,
