Model 33R877 type 0002 code 140757
Thanks for the advice. Will updateI would replace the fuel lines with quality hose such as Gates brand, and make sure the tank is spotless especially the exit nipple (debris gets caught in them). Along with that verify the intake gasket seals are good and not reused. This is not a governor problem; it is a fuel/air issue.
Was it an OEM carb?Changed carbs adjusted valves still the same thing hunts real bad only runs with choke half on. Changed carb head gasket and lapped the babes still hunts an dies without choke on
Had a couple motors did the same. one the main jet had dirt in it, the other look for air leaks around the carb.Changed carbs adjusted valves still the same thing hunts real bad only runs with choke half on. Changed carb head gasket and lapped the babes still hunts an dies without choke on
