Hey, Thanks so much! Yes opposed twin. Got you as far as starter goes. As mentioned, I just installed new oversized battery. Im gonna upgrade batt cables and check and clean all connections from battery to starter. I know from working on boats that 99% of time when there is a electrical problem it has to do with ground. i'm confident I will beable to spin motor over if those are inherent problems with spinning motor over. No OHV's to adjust. Next step will be to get the darn thing to start.
I'm gonna try to follow along with your suggestions for this problem of starting. Just to give little more history. When cold or not recently running. Damn thing fires up like a champ. Only after its been run does it give me problems. This in most blogs I've read in is atributed to the magnito. so I bought after market one and installed it. It was identical to the old one with exception of it having two grounding wires. I simply iliminated one, set gap at index card thickness, cleaned flywheel surface, and fired right up. Skipping ahead to attempt to re-start. I did pull plugs to check for spark. BUT, for what ever reason I did them one at a time. First pulling left side, spun over, saw spark, re-installed and went to right side. pulled the plug, spun over, saw spark and BLAM. She fired on one cylinder and started running. I quikly shut her down. Re-installed right side plug and wire, checked all connections and attempted to start. Wa,Wa,Wa (pac man dieing sound) Spins over but no start.
So, you mentioned one side sparks but other does not? I think we are on to something here. What next? Sounds like when attempting to re-start, pull both plugs and check for spark at same time.
