SleeperMower
- Feb 23, 2019
- 2
- 11
Hi, I have an 18HP opposed twin horizontal Briggs engine on my racing mower. The engine runs fine and is in good condition. The only strange thing it does is it locks up when you turn it backwards by hand. It does it once per revolution, in the same spot. When it does lock, I can go forward just a tad, and it will "unlock" and I'll hear a click. I can then continue spinning it all the way around backwards. Its also strange that I can hear mechanical clicking noise as I turn the engine, either forward or backward. I think this noise is related to what is causing the locking. The noise goes away when the engine is running, and no other problems occur. I don't know if the engine has compression release, but if it does I think it might be the cause of the issue. Either that or the governor inside is acting up? Any advise? Thanks!!!
