18hp kolher motor will not charge
Test procedure should be in the manual which I posted.
tractornut3
Could not get computer to down it did not have right software i guess engine man put some pages on here i used,igot 4 regulaters and i dont think all are bad would like to check them if possible imay not have it wired up right.
OLBIKER
What is your voltage from the stator???You check that by putting your meter on AC.motor running and putting a lead on each of the out side spades(White & white yellow & yellow)It should read above 28 volts AC at full throttle.What is your voltage at the battery running???It should be about 13.5 to 14 volts DC.I doubt you got 4 bad VR`s.
