skyflier22
- Feb 4, 2017
- 4
Hi, I have a 18HP briggs twin II on a Craftsman yt3000. I am unsure of the exact model but it has a 3 screw carb. I bought the mower for a hundred bucks, and it ran terrible the and it was pouring a lot of fuel out of the main jet in the carb so I bought a carb rebuild kit and cleaned the whole carb and replaced all the gaskets. It ran much better, It will run nearly perfect at full choke but when you push in the choke it will surge at full throttle and a low throttle it will die
I have cleaned the carb three times and it still will only run on full choke. I don't have any air leaks and I have good spark and spark plugs.
PS: I do mower repair an the side so I am fairly knowledgeable on them but this is stumping me:confused2::confused2:
