jakesmurray
- Jun 13, 2011
- 352
I am working on a Craftsman LT1000 and the motor won't start. I determined that the old starter was bad, so I replaced it. Now the engine won't spin, it just makes a squeal sound. If I reverse the flywheel by hand a little, the starter will spin it for about a revolution, but then it almost sounds like it is hitting something and it abruptly stops. I adjusted the valves to the proper setting, but it still won't turn over. Does anyone know what is happening? It is a 18hp Briggs OHV Intek engine. Thanks
