woo003
- Oct 9, 2023
- 4
hi, a very confusing one here.
I have a 17hp briggs and Stratton v-twin which is suffering from a number of problems. it is having trouble starting when cold. the engine will crank for ages on choke without going, however when I squirt some fuel in the intake it runs and stays running. I have already bypassed the fuel solenoid and have replaced all fuel lines, filter, spark plugs and governor-throttle spring. I have also tried a replacement carb and it won't run. I am suspecting further problems with the governor? then when I do get it running. it misfires and runs poorly. and it bogs down when throttling up. it also surges at full throttle. I have replaced all intake gaskets and seals and have also tried removing either spark plug boot when running and the problem fixes itself on either side????? any help would be appreciated the engine is model 350 777 vertical shaft. thanks.
