PTmowerMech
- Apr 16, 2018
- 424
- 3,243
Looking for advice on how to diagnose this RH hydro.
When I push the handle forward or backwards, it doesn't do anything, except whines a lot. It sounds like it's locked up. The other side does perfect.
The belt could be a little loose, but since there's only one belt, I'm pretty sure it's not that.
What are the things I should check?
So far, about the only thing I've checked is to see if the neutral switch was not engaged. It's not binding on anything. When you push/pull the handle, there's no movement at all. Unloading it, with the neutral switched pulled out and locked into place, the hydro was locked up. Like the neutral switch wasn't pulled out.
