christophert
- Aug 1, 2017
- 15
- 37
A 17.5 Briggs and Stratton came into the shop I am employed at. The previous mechanic has done an extensive amount of work on the engine (over $600.00 for parts and labor) and yet it still has issues. It seems after the last mechanic put it back together, it started pumping oil up the line towards the fuel pump. He put a fuel filter in the line to slow it down, but nevertheless it would literally pump all the oil out as it ran. I did a compression check and found it was losing compression. Upon tearing the top end down, I found it had a blown head gasket. I replaced the head gasket, cleaned everything up, and put the engine back together. Now....it is pumping the oil at a much slower rate, but nevertheless it is still pumping oil up towards the fuel pump. What are some more options?
