I had some bearing wear on my mower deck bearings. The jackshaft bearing has some play in it. I can not see how to disassemble it. It appears that the needle bearing stub shaft is welded to the pivot arm. This mower has the earlier style deck on it with a serial number less than 420000. Any guidance or knowledge as to how to get it apart?
