Well, I needed to figure something so I could have a running engine by Monday. I own a pressure washing business and booked for about 3 weeks out. I just went and bought a 22hp Harbor Freight for now. I'm not really a fan of running one of those but I'm either going to fix my Vanguard or buy a new Vanguard or Honda GX. I'll then buy another pump for the HF and have a back up cold water machine.
I only saved about $350 going this route over buying a new 23hp Vanguard. That's with the extended one year warranty. I almost didn't buy it because I told them I could buy a Vanguard 23hp with a 2 warranty for not a whole lot more. The manager told me that with the HF one year warranty I just have to bring it back every year and swap it out for a new one. I just have to buy a new one year warranty each time for $150. I gave him a weird look and said, "what"? I don't see myself doing that because it doesn't seem right but at least I'm covered for a year and, more importantly, will be up and running by tomorrow.
I'll get some pictures posted of the Vanguard. There's nothing left of the bottom 3/4 of the connecting rod. It got ground up to little pieces. I'll have to pull the oil pump apart and take a look before I even consider fixing it. After pulling the crank cover this morning I jumped the gun and ordered connecting rods and a gasket set. I'm about $150 in right now. I can't believe pistons are $100 a piece. That's crazy! At least I have some time to think about things now. I'll still post some pictures to get some advice. I might sell this hot water pressure washer this winter so wouldn't mind getting the old engine up and going. Even if I sell it I want it to be done right though so it's good to go for whoever buys it.
Just last week I came across a 16hp Vanguard with low hours out of a zero turn. I messaged him first thing in the morning. He said he had one guy ahead of me coming to look at it. I was just going to pick it up just in case. He had it listed for $120 too! Just my luck...lol
I do have one question about a electrical hookup for my hot water system. Coming from the hot water control board there are two wires that are spliced into two wires coming off of the voltage regulator. I believe it's getting ac to power the transformer or igniter for the burner. My question is are those two yellow wires coming off of the voltage regulator the same or is one like positive and one negative? I would assume they would be different colors if so. On the HF engine the two wires are both blue. I'm just wondering if it matters which wire gets spliced into what? Both the wires running from the pressure washer control box are black so I assume it doesn't matter which one goes where.
Thanks!
