If you try to start it, it will bump and kick back (counterclockwise) a bit. If you continue to bump it, it will kick back enough (180 degrees) and it will fire right up.
If the first time I try and it just bumps, I can open the hood and rotate it by hand counterclockwise about 180 degrees and it fires right up.
I have replaced the Starter, Solenoid and Battery but has not fixed it.
All suggestions greatly appreciated. Thank you~~~~~~~Ron
