MStanfield
- Aug 23, 2016
- 8
I have a 1500 Ferris with Kawasaki FH721V.
Without warning, I have a no start condition. After searching, motor will crank but no spark to either cylinder. If I remove the kill wires from each coil, it starts and runs perfect. I went through and tested continuity at each safety switch and ignition switch; all good. I followed all wires from coils to switch; cannot find a break (i.e. mice); this also has continuity from kill wires to switch harness.
What else do I check? Coils were new this spring...motor runs great otherwise
Can somebody help?
Can somebody help?
