Mwh0428
- Dec 19, 2011
- 41
- 164
I have a 14 hp Briggs and Stratton engine that I took of a newer simplicity and put on a Murray and It started smoking really bad and then it died I replaced the coil pack and vacuum powered fuel pump and it runs but burns oil. Then I bought a new oil filter and put that on after draining all the old oil and the old oil was as runny and smelt like gasoline is this an issue that can be fixed or should I just send the motor to the scrap yard
