trailjammer
The engine starts up every time ok but we have to feather the choke ~50% on to keep it running.
We have cleaned the air filter & changed the plugs. Gas is fresh....trying to eliminate easy issues.
I played around with the needle screw (not sure of the correct name for it)... located in the front of this carb --> choke was still required to keep the motor running.
I am thinking the carb float level? Maybe a clogged port somewhere in the carb? Where should we start?
