145bt Husqvarna blower
Jones334
How many turns out is the idle screw set? I just need to get in the ballpark. Thanks in advance
Idle screw ?
Do you mean the throttle stop or the low speed jet ?
Low speed jet needles are 1 to 2 turns out.
Throttle stops get would in till the trimmer is running fast then backed out till the head just stops spinning
After that you readjust the Low needle then the throttle stop and continue doing so till you get a smooth transition from the L needle to the H needle when accelerating.
