Ever run across a Skilsaw version?I have had customers bring in the poulans micro xxv and the craftsman variants not oiling. If it is not just the oil line rotted off i tell them i won't do any more. The check valves are NLA and every used one i or a customer gets off a used saw doesn't work. So to avoid charging for labor and not fixing the saw i just tell them i can't fix the oiling issue.
I having to turn away old Homelite saw now as the oil pump diaphragms are no longer available. Owner don't that like that so I say you can always carry around a hand oiler as I did for 10 years for a McCulloch Wildcat I had. Finally had to retire the saw once the PNC wore out.
