12v outlet addon
vernonator
I have an Exmark LazerZ E mower and would like to start using it for more than just mowing. I am going to put the hitch kit on it so I can aerate, spread, sweep and spray with it. For the sprayer i would like to add a 12v outlet. There is a cut-out on the control panel, has anyone added an outlet to their Exmark? How difficult/easy was i to tap into the power?
Any help would be great!!!
Thanks
Mark
Im no Exmark expert, but adding a 12v outlet is no problem. Just make sure you put an inline fuse on the outlet.
As far as the charging systems and what they will allow you to run, I have no idea.
