12hp engine budget build
Wick99
Will any parts from a 14hp ohv engine fit a 12hp ohv engine? Carb? Cam? Rod? Valve springs?
How long is a piece of string ?
alternators are standard size , both stator & rotor right across the entire range .
Most carbs will interchange as will the starter motors.
After that it will depend upon the series ( first 2 numbers of the model number )
