128LD string trimmer won't start
zamboknee
My trimmer all of the sudden sputtered out while I was using it. Couldn't get it to start after that.
It would run with the choke fully open for a bit but wouldn't stay running.
Here's what I've done to try and resolve the situation.
  • Replaced spark plug
  • replaced air filter
  • replaced fuel filter
  • drained gas and replaced with a premixed 50:1 fuel/oil.
The previous gas was kind of green. I put some gas water remover in the old batch but that didn't seem to help. Hence the new gas.
Any idea what's next to look at here?
zamboknee
Is this a scarred piston? carburetor replacement?
Thoughts?
dougand3
Running some on choke points to fuel delivery problem. Can check with a spray bottle of 2 cycle fuel (don't use starting fluid - no lube). Get it running and keep spraying fuel into carb throat. It you can keep running 15 secs or more, I'd disassemble, clean and replace diapraphms in carb. Or buy a new one.
dougand3
Carb is 545081848. OEM is $32 or AM is ~$11.
