ericmows125
- Mar 27, 2013
- 2
- 4
Hi everybody!
My briggs and stratton has been annoying me lately. When it runs, it hunts when at half throttle or higher and when I turn the air/fuel mixture screw to stop the hunting it does absolutely nothing. Also if I try to make it idle slow it starts to hunt and then eventually shuts off. I have replaced the needle valve, the bowl and gasket, and have soaked it in kerosine to clean it.
FYI: when I got this mower it had water and ice in the fuel line. The bowl also had rust on the bottom.
Engine model number: 28T707
Type: 1154-E1
Code: 000804ZD
Type: 1154-E1
Code: 000804ZD
