tractorguy
- Apr 25, 2014
- 1
- 2
Hello, I am rebuilding a 12.5 hp briggs and stratton engine. I line up the timing mark perfectly on the crankshaft timing gear with the timing mark on the camshaft. When I do this, my exhaust valve opens right after my intake valve does. Has anybody else ever had this problem? If so, how did you fix it? Any solution would be much appreciated. Thank you.
