1190-H
b1mmuo27
I purchased this tractor used. It needed a centre spindle & a little welding on the mount for it. An 84 year old gentleman hit a stump with it & his son decided it was time to sell it. It runs beautifully & has only 540 hours on it. I can't find much info on it so I don't know what year it is either. The thing I have noticed is the electric pto is loud & producing a grinding noise when the pto is off or engaged. It works fine but I was wondering if I should take it off & have a look.
motoman
b1, If no one answers here try TractorByNet. You may be in the wrong forum.
b1mmuo27
Convinced?
What we may be running into somewhat is this could be a canada only model. The other thing is even though the are calling the 1190-h a model number it is in fact a series number Maybe we could do more with the number from under the seat which will start with either 13 or 14 and have a series of numbers and letters.
b1mmuo27
13AG618H595 That is the model number. I also gave the clutch adjustment nuts each a 3/4 turn. Sounds good now.
